- Apr 22, 2016
- 965
Mostly gone. Been selling for going on 2 years. Was a 100 x 100' building packed full so you could barely walkAny other bargains at the shop you're helping to liquidate?
Why didn't you call me?Mostly gone. Been selling for going on 2 years. Was a 100 x 100' building packed full so you could barely walk
I plan on getting one whether I use it for this project or not.They come in handy . Plus , use them in a mill , on a drill press , or a lathe . Bet your countertop is emptier than mine !
Thanks for the response. I just hope my 'beginner's luck' doesn't run out until I've completed the project. I failed to mention in the earlier posts, I've been doing the cuts with the adhesive paper still intact on both sides. I suspect that probably has something to do with the success. Also, these holes were drilled on my milling machine using the power quill. I have it set on the slowest speed possible, and I'm milling at 600 RPM's. The quill feed seems painfully slow but is probably a significant reason for the favorable outcome. I've been tempted a time or two to feed by hand, but I'm sure there's no way I could be as uniformly steady and slow as the power feed. Hopefully, I'll have the same outcomes on the larger holes. We'll know in a day or two.Terry, you got lucky drilling all those holes! I've tried hole saws (great when concentric), plain bits (okay if you go slow) , forstner bits (utter fail), and a cheap trepanning tool (also a destructive attempt). Mixed luck with acrylic. People who work plastics often say to use drill bits that have the cutting edges dulled (blunted square to the cut) with a stone. It supposedly prevents cracking. I have bought "acrylic" bits as singles for larger projects in the past. They work best in a drill press as opposed to a hand drill. Either way, that's a lot of holes you've successfully drilled without a crack, time to go buy a lotto ticket!
The material I'm using is 1/4" 'cast acrylic'. It was recommended by RJSakowski in response to a separate thread on a completely separate issue (see my thread titled 'How to make an aluminum drawer liner' - not sure how to access it here). It seems to be very easy to machine but as so many have pointed out (including RJ), it is susceptible to chipping and breaking.If this was already mentioned then please disregard......
Im not sure about the specific material you are working with but i was taught when cutting plastic, especially thin sheet material, to cut in reverse using a fine tooth hole saws to get the cleanest cuts. In my experience, You dont need to apply much pressure and it tends to be much easier on the plastic breakthrough without tearout and cracking the work piece.
Dish soap sounds like an easy trick for cooling. Melting (so far) has not been a problem - I'm assuming because of the slow RPM's and quill feed rate.I've used regular holesaws on acrylic with good results, I use dish soap as a coolant to reduce melting the chips.
A sacrificial piece of wood or ply for a backer has definitely helped with not shattering on the last bit of the cut.
Stu
