Another “Can you identify this tool?” post.
OK---give us some more clues to help us figure these out--like---are both tools exactly the same---what are the dimensions of the upper and lower rams---are the gray adjusters made of wood or metal, and do they have any little wear marks from pressure of the ram---is the clearance for the bottom ram loose or very snug and are there any locks for the adjustable lower ram once the adjuster has the desired height---how deep are the concaves in the rams, and are they the same diameter---and any other clues.
I'm thinking maybe for pressing lenses on watches cases--or for some use in making the small wood planes since he had lots of them---I will look for my cloth button press and the two piece upper and lower metal buttons that get pressed together to fasten the cloth piece on---I know I still have it--if I can still find it--had it for at least 45 years---this gives me a thought of what a new thread I can start---Dave
My guess would be either a button maker or grommets. The anvil looks dished and if it is, then it's likely buttons as grommets usually have a flat anvil with a raised center for rolling the sleeve/boss.
Depending on the size across the anvil, could it be a restaurant juice press? I repaired a similar press for a friend a couple of years ago. It was permitted by the health folks even though not as nice a finish as these. Just a thought.....
Both ram and anvil measure 7/8 dia. Sliding fit in in the holes . Both Ram and anvil have a semi-spherical hollow about 3/16 deep. The edges are fairly sharp but not razor sharp. Could maybe cut leather - but the minimum distance between ram and anvil -at full stroke is 5/16". The maximum stroke is about 3/8", but for half the stroke, the ram is retracted inside the housing. (which would strip the parts off the ram - if it was a punch.) No dings or wear marks on the tooling. The adjusters are metal. As seen in the pic the base has two magnets- to hold the adguster to the base when not in use.. The finish on the presses would be overboard for a manufacturing environment. The mounting holes in the base even have plastic inserts.
Thanks for all the input!!! Of course its not important to know definitively what they are for - but its always interesting.
Jim
The height adjuster on the bottom shows that normal use would see material of various heights or thicknesses being used and the height adjustment is not a very critical adjustment. Could it be a jig to hold something round while work was done to it? Interesting virtual reverse engineering practice.
