Anton Tool magnetic transfer adjustable angle block
As far as taking it apart, I was able to find this picture:
Source: http://www.lostcreekmachine.com/surface_grinders.htm
Scroll down toward the bottom, and it is the first item listed for sale under magnetic transfer blocks.
It doesn't look like there is anything mechanically holding it together.
Dried/hardened grease/coolant/schmoo might be gluing it together. Or maybe it has become magnetized?
I'm not sure, but I wanted to pass along the picture in case it helps.
WOW! 5$ not a sale, not stealing - you've invented a whole new category for dealing - I only wish there was a term for it!
It should be held together with residual magnetism. that is good... Prevents swarf from getting in...
-- and now you know how to set an angle. You can use an angle block, or a sin bar to create the angle. You can re-calibrate it with a parallel under the pins and taking a skim pass. I haven't seen one in 20 years but it is a fantastic accessory to your grinder. I bought a 2 axis magnetic sine plate last year so I'm good, but that is a very useful piece of equipment....
Thank you all!
You've been great! I have the wood box, too. But a piece of the lid is missing.
Andy Pullen
