I usually use half the spacing distance at each end for astetic purposes. If you use @twhite spacing of 2 1/2 inches between holes, making 7 1/2 inches, leaving 1 1/4 inches between the centre of the holes to the end.
I can’t believe how quickly you responded to me. Also I’m embarrassed that I didn’t figure that out!! Thank you for being smarter than me. JR49
Or draw a straight line in AutoCAD 10" long and use the divide command, 4 spaces...Method, no math needed; make a mark with a center punch at the center, then take a compass or trammel points and swing an arc on both sides of the center punch mark, the result is 3 equal spaces.
