Okay, and I know it was late whe I was attempting to pose the question. How does elastic modulus play into a decision to heat treat a part? My position was elastic modulus is outside of the mechanical properties and tests we use to determine how a piece of material is used, or when an alloy is added to improve tensile strength, resist the affects of heat or cold, wear resistance, impact resistance, ductility, etc. Elastic modulus is proportional based on the force applied through compression or extension and from that degree nothing changed if the part is heat treated. This is a lot of physics which I try really hard to not concern myself with on a daily basis.
A 4" length of .250" Sq. HSS prior to heat treating and after heat treating may have the same elastic modulus but the mechanical properties change dramatically after heat treating. I know we are not going to get the hardness of HSS from a case hardened 1018/A-36 but service life is improved greatly. I think the one item or piece missed in the question regarding 1018 and A36 is why 1018 has a higher tensile, less elongation, higher yield strength etc. This is due to mechanical changes caused or induced by the forming of the bar, because the chemical compositions are almost identical. These changes are also afffected if the bar is rolled or drawn (drawn usually has less stress), along with the the different drawing methods. The topic did receive comments on distortion, warping etc. along with the results which may happen during machining. It helps to ask for mill certs from the supplier to get a better picture.
