Rustrp
I used a bad example because 12L14 is essentially 1215 w/o lead. They are both rated as a "range" of E. (Elasticity Modulus, or Young's Modulus)
A better example would be Cromium-Molybdenum steels. A tiny amount of Cromium increases the E factor quite a bit, then additional larger amounts do also, but at a slower rate.
Look up the E on different materials that are used in steel alloys, and you will see where some will impact the alloys E quite a bit and others hardly at all. Not trying to argue as these tine amount impact NOBODY on here! Just wanted to state what/why I added that. Only that part remarking on mechanical properties was "not quite" right. There are some material alloys that increase the E by several times, but stuff I doubt any of us will ever see let alone use. I am just one of "those" picky people.
Tensile Modulus - Young's Modulus or Modulus of Elasticity - is a
measure of stiffness of an elastic material. It is used to describe the elastic properties of objects like wires, rods or columns when they are stretched or compressed.
Tensile Modulus is defined as the
"ratio of stress (force per unit area) along an axis to strain (ratio of deformation over initial length) along that axis"
It can be used to predict the elongation or compression of an object as long as the stress is less than the yield strength of the material.
Temperature is the greatest "changer of E.
Cr-MO Steel Cr ½%-2% E=29 @ 70
oF
Cr-MO Steel Cr 2 2 ¼-3% E=30.6 @ 70
oF
Cr-MO Steel Cr 5%-9% E=30.9 @ 70
oF
Paul (with apologies for whatever! LOL)
