- Feb 1, 2015
- 9,624
Rather than using an existing taper to set the taper, I would turn two collars on a bar. The first collar would have a diameter of 1.0000" and the second collar would be located 3" further along the bar. The MT3 taper is .60235"/ft or .1506" in 3" so the second collar diameter. would be 1" - .1506" or. 8494". Make the collars about 1/2" wide for convenience.
The angle between the taper and the spindle axis is 1.4368º so for 3" along the spindle axis, the compound will have to move 3"/cos(1.4368º) or 3.0009". Zero the indicator on one collar and move compound exactly 3.0009" to the second collar and you should have a zero reading if the compound is set correctly. Adjust the compound angle as required. It will help to turn the section between the two collars so the dial indicator doesn't have to be moved to clear.
The advantage of this method is that it doesn't rely on the accuracy of machine alignment.
