- Feb 22, 2012
- 924
I am considering a future AR build, at the point where I'm still trying to figure out if it's worth it, and how involved it would be (yes - I can put all the parts together if I purchased them (done that before once or twice...), but am more interested in making as much of it in the shop which is what the consideration is all about). Browsing all the forums, it seems the only parts people discuss RE machining is the lower casting.
1. of you people that build ARs, do you machine any of the other components? or is it just the lower that gets to be machined (80%, 0%) ?
2. if so, what is the benefit of machining your own lower (considering cost of all other parts, the savings on machining your own lower seems insignificant to a certain degree)?
3. If you machine more than just the lower - what other components do you machine? is there a good reference to check for following through?
Thanks,
Sharon
Thanks,
Sharon
