- Apr 23, 2018
- 6,537
OP shouldn't have to worry about original part dimensions if the shaft is worn or boogered. Turn the shaft down, install a sleeve, and turn the sleeve to whatever works for your replacement bushing. The sleeve is optional if you make a new bushing with an undersize bore. Works for the shaft carrier the same way. Since it's a countershaft, you can still use your lathe to do the work. Sounds like you have a good practical exercise on your hands!
