Just wanted to give you guys a heads up and recommendation about this wrench. This is Bahco's thin jawed adjustable wrench that is used on those annoying thin nuts or bolts. You know, the ones that you can't get a regular wrench on. The build quality of this tool is top notch. The ground jaws are ground at an angle so it is thinner at the tip; you can get into really tight spaces with this wrench. The jaws open to 38mm so it can handle a very wide range of fasteners. I also own the same wrench without the thinned down jaws and together they are awesome for working on all sorts of equipment.
The good thing about Bahco wrenches is that they stay put. You know how most adjustable wrenches loosen up as you use them? Not these. They stay where you set them until you move them.
I also own their standard adjustable wrenches in 6, 8 and 10" sizes and I don't think you can get better ones.
BTW, Snap-On owns Bahco so all of the adjustable Snap-On wrenches are Bahco wrenches.
