The new ball bearings that I have to install have better seals on both sides. There is considerable drag created by the seals. Plus, the press fit of the bearing on the shaft is a bit too light for my liking.
I want to add some glue between the shaft and inner race as insurance to prevent the race from slipping on the shaft in service.
The glue has to be applied before assembly because of the design. I want something that would not set too quickly so that there is time to assemble the parts before the glue sets. Also, the glue should not be permanent in case the bearings need to be replaced again. Bearing size is 6307.
Any ideas about what glue/sealant/compound to use?
Thanks for reading this far. Mike
