Bearing replacement on my PTO driven screw type log splitter
H-M experienced a site wide outage on January 23. To the best of our knowledge, the site has been restored up to January 1, 2020. Common problems are going to be missing posts, reverted membership levels and other time related problems that will potentially have been lost between January 1-23.
Please click on this notice to be taken to the Site Support Forum so you can learn more about what happened, what is being done and post a support request so we can help you get your issue resolved.
OldMachinist
Bronze
Rest In Peace
Mar 1, 2012
1,140
The bearings on my screw log splitter were getting loose and needed replacement.
The original bearings were stamped steel housed garage door bearings. I didn't want to replace them with the same so I cut out the old tube that the bearings were pressed it and made a new one.
I had a piece of 3-1/2" DOM tubing that I machined for the new tube.
The new bearings are insert bearings and should last the rest of my life time.
The frame needed to be bored out for the new larger tube.
I also added a keyway to the shaft and driveshaft yoke. The way it was just driving it off a bolt thru them it would work loose sometimes.
It's all back together and ready to tackle my pile of logs.
This thing will split a 30" dia. by 18" long round in seconds.
DSCF1888.JPG DSCF1879.JPG DSCF1880.JPG DSCF1881.JPG DSCF1884.JPG DSCF1887.JPG DSCF1882.JPG DSCF1883.JPG DSCF1885.JPG DSCF1886.JPG DSCF1889.JPG
Michaeljp86
Jan 2, 2013
173
Looks like those bearings put up with a lot of use and abuse. You should have a video of that thing.
