- Sep 7, 2019
- 674
Hello all! I hope this is the right forum for this topic.
So I'm looking to get better at grinding HSS lathe tools. I've had a small Atlas lathe for years but so far I've only really been touching up the bits that I received with the machine.
I'm attempting to learn more about tool grinding but I'm having issues with my bench grinder, namely bad vibration. The grinder is an old Taiwanese "Panther King". I'm sure it's not the greatest but it runs smoothly and quietly with no wheels. Run out on the shafts is minimal if any at all. So I put some new white Norton wheels on it (6"x3/4") with the included blue plastic arbors and I can't get the wheels to run true.
I tried clocking the wheels differently, every 1/8 turn or so and there is an orientation that minimizes the side to side wobble but in that orientation the wheel lopes like a camshaft by more than 1/16".
I'm thinking that the loping must be due to either the wheels not being true or the slight bit of play in the blue plastic arbor stack. The side to side wobble is probably from the large washers that hold the wheels to the shaft. They are stamped as opposed to machined on this grinder.
Should I just install the wheels with the best side to side wobble I can find and then dress to true?
Any advice would be appreciated!
Thanks guys!
Thanks guys!
