Hi Again, been getting ready to machine this new spindle for the lathe.
Been getting things together for the boring for the new bearings, took some hard and long thinking of how to do it,
I'm pretty confident that it will work, and if it don't I'll be so embarrassed that nobody will ever hear from me again.
Not really, but will fell very dissapointed, as I always do when screwing something up.
Now I have some questions about the bearings.
Ive talked to 4 or 5 different people and they all have different Ideas about how to install these bearings.
One says that I need 2 nuts, one before the bearing and one left hand nut after the last bearing to adjust pre-load..even though they are ball bearings. I think he don't know, miss-lead or whats going on, I thought that pre-load would be for bearings like used on a trailer, Race, Bearing, Washer, Seal, Nut to adjust pre-load...
I could go on and on about the other ideas but no need to, I have a way I think would work, besides this isn't some Hi production cnc lathe, its just for occasional use for me.
The first bearing will be flush with the bearing cap on the right side, then to the right of that will be a bronze thrust washer and then the machined shoulder of the spindle then the spindle threads..
To the left of that bearing will be a spacer, (the width of the cap is a little wider than
the 2 bearings by about .375) so that would be the width to bring that bearing flush on the left side.
Then to the left of that would be another thrust washer, thin machine washer and a lock collar, after that to the
left is pretty simple, pulley, new small bearing etc.
I was going to do all the machining here except the threading of the 1.125x12 thread..
So that's about it, If you think I'm wrong please tell me, don't wait till I'm done then tell me I screwed up like my
A.. H... brother would do..
Thanks Again,
Tim
