[4]
Bought a grinder at auction and not sure i need it
[3]
[10] Like what you see?
dado5
H-M Supporter - Gold Member
Dec 10, 2012
28
I bought this at a recent auction. 1hp, has 2 diamond whhels. I pretty much only use hss lathe tools since I'm a beginner. Just getting started with mill as well. Is this only good to grind carbide tooling? Shoild i change the wheels or just hang on to it until I'm more mature as a machinist. I have an 8" baldor grinder which grinds my bits now pretty well
tweinke
Mar 24, 2014
896
Aluminum oxide and CBN wheels are available to fit that grinder which would make it a nice tool for your HSS tools. Just sealed the deal on a similar grinder myself.
kd4gij
Feb 7, 2011
4,698
You can send it to me to use until you decide to use brazed carbide tooling. :laughing:
Or you could put wheels for your HSS bits and use it.
D
Deleted member 43583
Guest - Please Register!
Nice grinder, you will evolve to wanting and needing it. Hang on to it!
dado5
Dec 10, 2012
28
As it is set up (one coarse diamond wheel and one medium) is it just for brazed carbide tooling? seems like a very limited use. Cant use it for index carbide right, they are disposable.
mikey
Dec 20, 2012
4,769
Dado, you can use that grinder for HSS lathe tools and brazed carbide tools. Just need the right wheels. You can have a green carbide wheel on one end to shape the brazed carbide and a diamond to final sharpen it. Don't underestimate the efficacy of brazed carbide tools - when shaped properly and sharpened, they are really good tools. For your HSS tools, CBN will work well for you. This type of grinder will allow you to grind all faces of the tool, including the rake angles so it is definitely a keeper.
You are correct. For inserts, you either use a machine like a Accu-finish to sharpen them or dump the insert when dull.
westsailpat
Feb 14, 2016
619
I don't know what you paid for it , I assume no where close to what a new one would cost . I would keep it . I never did like those wheels with the holes in them . I much liked the solid diamond wheels . Why aren't you using brazed carbide bits ? Your new grinder would work awesome on those bits .
Groundhog
Jan 20, 2016
976
Good score. I would guess you can't sell that one for enough to get diamond wheels for your 8", so maybe store it until you have a need for a grinder with diamond wheels (which I'm sure you will eventually need).
Or, if you don't have room I could store it for you. :frog:
Chipper5783
Sep 25, 2014
745
Don't sweat it, start using it. Those diamonds will grind the HSS just fine. Of course, be kind - use your other bench grinder to rough in the tool shape and finish it up on that grinder. Be diligent about working the whole face of the wheel. It is too bad that both the wheels are "coarse" - still, if you use just very light pressure and a few passes you can get a surprising smooth finish.
I have a similar pedestal tool grinder (except 10" - which makes for pricey wheels and one face & one radial wheel) and I grind brazed carbide (which ends up grinding some of the steel base) and HSS - it works beautifully. The brazed carbide is a great tool bit. Especially if you are cutting some ugly nasty material (i.e. welded / flame cut steel) - you can touch up the edge every pass, gives you the hardness of carbide, and still cheap. I find the diamond cuts so much better than a green wheel.
Did you get the miter tool that slides on the table? I ended up making my own (when machines go to the auction - the small pieces seem to disappear).
Try it, let us know how you make out.
http://www.hobby-machinist.com/threads/carbide-grinding-implements.55905/#post-460884
http://www.hobby-machinist.com/threads/carboloy-excello-tool-grinder.37715/
4ssss
Brass
Apr 25, 2017
545
My opinion is to sell it. These carbide grinders that MSC, Jet, and the other Chinese grinders sold on well known tool web sites are junk unless you rework them, starting with taking them apart, and turning them in a lathe between centers to get the spindles to run true. There's Youtube videos of how to do it. If you put a decent Diamond Wheel on them out the box you can pretty much kiss your money goodbye. Also, unless you can mount a brake on the spindle, you'll be sitting there for an hour waiting for it to slow down enough so you can reverse the wheel to grind the opposite angles on your tools. They're getting $250-$300 for a good Baldor carbide grinder on Craigslist, so do yourself a favor, and if you don't need this one, dump it and get a good one when you do. And by the way, you will destroy that wheel grinding HSS, and it's not a cheap diamond, so take it off that grinder and keep it for your new one.
Silverbullet
Gold
May 4, 2015
3,420
Keep the grinder , it's only as good as the machinist who uses it. You can set the angles , use the drip coolant and grind your tools to the exact shape you want. It's made for lathe tool sharpening.
EmilioG
Jul 20, 2014
1,357
The Baldor is awesome, but over 1k$ new.
D
You must live in Craigslist Heaven.
D
Okay, I will send you my Xmas list. But for a start I want a surface grinder, a 12 gauge sheetmetal finger brake, a Miller tig machine, and a 6" D1-4 3 jaw Bison set tru chuck!
Seriously, Craigslist is awful here on the gulf coast of Alabama. It is a wasteland of over priced junk. There is typically nothing on it and when there is, it is ridiculously priced.
4ssss
Brass
Apr 25, 2017
545
I know, but the Alabama shore isn't known as a hot bed of manufacturing. It's pretty hard to find tooling when Harbor Freight is the industrial supplier of the South. Merry Christmas, and here's a few craigslist finds for you to drool over.
https://boston.craigslist.org/bmw/tls/d/norton-6x18-surface-grinder/6426964019.html
https://newhaven.craigslist.org/tls/d/surface-grinder-reid/6428728367.html
https://harrisburg.craigslist.org/tls/d/brown-sharpe-618-micromaster/6416307128.html
https://westernmass.craigslist.org/hvo/d/reid-surface-grinder/6425850636.html
https://plattsburgh.craigslist.org/tls/d/pexto-24-finger-box-brake-16/6427579744.html
https://hudsonvalley.craigslist.org/tls/d/tennsmith-52-finger-brake/6413575198.html
https://capecod.craigslist.org/hvo/d/roper-whitney-24-sheet-metal/6383001779.html
https://longisland.craigslist.org/tls/d/miller-welder/6426427763.html
https://boston.craigslist.org/gbs/tls/d/miller-tig-stick-welder-water/6421559765.html
https://southjersey.craigslist.org/tls/d/welder-miller-econo-twin/6385919497.html
https://syracuse.craigslist.org/tls/d/miller-maxstar-150-stl-stick/6377817879.html
https://jerseyshore.craigslist.org/tls/d/welder/6425635834.html
EmilioG
Jul 20, 2014
1,357
You can't judge a machine by photos alone(re: CL). A seller can write anything. Unless you know what to look and check for AND if the seller will allow, you're half way there. Remember, they're selling for a reason. Some good, some not so good. Asking the right questions and judging the response is also key. A lot of caution when buying a used lathe, mill, Surf. grinder, etc....
Hit-N-Miss Tom
Newbie
Dec 6, 2017
14
View attachment 250075View attachment 250075
I have a Baldor similar grinder with a diamond wheel on one side and silicon carbide (green) wheel on the other for grinding usually HSS. Also use the diamond wheel for tungsten TIG electrodes (watch the dust!). I use it and a basic Milwaukee grinder all the time. Diamond wheels get somewhat pricey and there are more that one type/quality wheel, but they last a long time and can put a mirror finish on item being ground. Keep the grinder, you will be using it sometime.
[6]
[5] [7]
