I ton is 2000 lbs, 1/2 ton is 1000 lbs and lathe is 960 lbs.Do not attempt to lift the lathe with that setting of the hoist. In that setting it is rated for 500 lbs and the weight of the lathe will exceed that rating. Even if the hoist doesn't fail, it is not very stable in that position.
I would use the innermost position and use the hoist to drag the lathe off the truck bed until I got to a point where I was lifting vertically. I would also shorten the strap as much as possible.
My bad. I was thinking of the 1 ton hoist. I have the same hoist as yours. Personally, I wouldn't trust Harbor Freight's safety margin in their ratings though.I ton is 2000 lbs, 1/2 ton is 1000 lbs and lathe is 960 lbs.
I agree it’s more stable at shorter lengths. Now that it’s down, I can get closer without hitting the tailgate and use a shorter boom.
I borrowed my friends 2-ton, and it’s WAY better than the crappy 1-ton version I have, way more stable. I do need to upgrade to the 2-ton.My bad. I was thinking of the 1 ton hoist. I have the same hoist as yours. Personally, I wouldn't trust Harbor Freight's safety margin in their ratings though.
Anyway, I'm glad that you were able to get the lathe off the truck without incident.
