- Feb 2, 2013
- 3,627
AMP readings are taken with the amp meter as part of the circuit if you don't have a clamp on type meter.Not too clear on the amp thing. I have an amp setting on my digital meter. I don't however know where to stick the probes to test amperage.
another way of saying it would be to disconnect 1 power wire from the motor put one lead of the amp meter on the power wire (black) and make secure so the test lead wont slip off, then take the other test lead and hook it to the motor wire you had just removed
the power wire from(1,7 pairing), making the meter part of the circuit to test amp draw. i would test 2 different power legs in this way
black to 1,7 pairing, then white to 3,9 pairing.
does this make sense to you?
let me know i'll try to explain better if not.... my concern is for your safety you will have wires exposed, please turn off the circuit when working on it)
mike)
i'll be out to dinner until later on, but i'll be happy to answer any questions when i return home!
