I bought this old gal last month off of Craig's list mostly to save it from the scrap yard .... ok Maybe I have a case of cheap junkitus as well .
When I got this little mill it had an air cylinder on it in place of the original lead screw and power feed .
As it didn't work very well and seriously limited table travel I took it off and began thinking of ways to make it a hand Miller .
And well here's what I come up with so far for zero cash outlay .
I found a rack and pinion off of an old table saw fence of all places and mocked it up .
As this is more of a proof of concept test run then a finished product I did the install without making any changes to the mill itself and have everything mounted securely enough I think to make a test cut in some aluminum once I find a cutter .
I think if this mock up works out I'll search the local salvage yard and see if I can come up with a rack and pinion of a lathe carriage or something similar to do a permanent higher quality job .
Throw your thoughts and suggestions out to me .... I am very open minded as to other solutions to make this old girl work again
Sent from my SM-S820L using Tapatalk
