- Jan 25, 2015
- 2,558
I've got a rigid eccentric flare tool in the drawer, but it's for 37 degree flares and only single flare. I use it a lot for making hydraulic lines for implements. Works great and is esay to use as it essentially "rolls" the tube end instead of forcing it tho expand. No good for 45 automotive flares though.Wow, they throw true safety out the window in the name of safety inspections?
Sounds like a lot of similar stuff is going on up there.
The above bender still works well on steel. When I have a lot of hydraulic tubing to run it so much faster and easier on the hands than my ridgid or imperial roller flaring tools, which are night and day above the type you posted in pic one.
The syke pickavent style is a simple pull on a long lever. very quick, dies don't mar the tubing either, very similar dies to the mastercool/clones.
The hydraulic ones are not bad, but it still a lot of pumping and it can get tiring if doing a lot.
I actually first went looking for those lever type flare tools. But once it woudl be at my door, we're talking within 100 bucks of the hydralic kits you can also use on the car. Then I thought about buying aset of dies for them and making the rest of the 9relatively simple) tool, but a set of dies are almost as much as the entire flare tool.
They've got me boxed in coming or going......
