- Jun 12, 2014
- 4,812
I started out with a mill, found it more useful for the type of work I was doing. Eventually bought a lathe and can see a good argument to get both if you can afford it. I have gone with new machines, in particular if you are a newbie and do not know how to thoroughly check out the machine. I eventually upgraded to a larger knee mill and heavier lathe, looked at a few used mills and most needed repairs/parts were expensive. If you have the time and experience then the used machine market is a viable option depending on location. It is also an economical decisions and the scope of work you want to do. If I was buying on the used market, I would look for a mill as opposed to a lathe, they are easier to check out.
QMT/Matt has a new mill in the works which is the PM-728V-T which looks like a very nice (smaller) mill made in Taiwan. Otherwise the 727V/30MV are popular models with positive reviews. Going 230VAC in machines is preferred, and the variable speed is very nice. If you plan on doing larger work, maybe look at the used market for a knee mill. As far as lathes, the 1236 is a good all around size, I would look for a standard D1-4 spindle mount and get a QCTP. Combining the purchase may save some on freight costs. Tooling/accessories on the lathe is more expensive than a mill.
