Can I just buy a T-Slot Compound for my Lathe?
confab
Sep 14, 2021
6
Hi. I just bought a 12X36 Asian lathe. It's a Harbor Freight, but the same design was marketed under the Enco, Grizzly, Brimingham, brands and some others.
The compound is missing and all I want is a replacement for the stock T-Slot type that came with it.. And I can't find one?
I find a bunch of smaller types. I see an "AT300" type that is larger, but no T-Slot.
If I go to the manufacturer websites, I can buy them in pieces, but the cost goes WAY up if you do it that way.
Do you know where I can just get an affordable compound to fit my machine?
Thanks!!!!!
rabler
H-M Lifetime Diamond Member
Feb 25, 2021
904
No ideas on actually getting a compound, but an alternative is to mill a solid piece in lieu of a compound. Claims are much improved rigidity. And you'd have something usable while keeping a lookout for an economical used one.
Jake P
H-M Supporter - Silver Member
Mar 23, 2021
200
In case you’re not familiar with what rambler is referring to, here’s a link to a solid tool post designed an d built by one of our members here:
confab
Sep 14, 2021
6
Yeah, thanks. I had thought I might add a t slot table directly to the slide for a tool post, actually.
That's a good idea. But, I do use the compound sometimes.
It is just hard to believe there's a literal sea of the tiny imported ones, but nothing larger?
I could adapt something from a SB or an Atlas, I guess. But I'd rather have the big, Asian arrangement that came with it.
Any websites you may have run across with used parts or that might stock such a thing complete would be very helpful.
confab
Sep 14, 2021
6
What material did he use? Does anyone know?
confab
Sep 14, 2021
6
Oh! It does. I'm sorry. I opened it into a slideshow and didn't see. Thank you.
Question: If I were to try to build a slide. What kind of material should I use?
I think the one on the other (mini) lathe is iron. But I don't know any more about it than that.
Cadillac STS
H-M Platinum Supporter
Jul 20, 2012
1,088
I agree on the solid non-cross slide for rigidity and to get up and running today.
Could look for a cross slide from an Atlas 10 or 12 on eBay. Maybe other brand there too. Then drill holes to match your slots if needed.
I just searched eBay for "Lathe Cross Slide" and there are many choices and prices. Be sure you get one with a swivel base.
Cadillac STS
Jul 20, 2012
1,088
Also you may not need a T slot on top. You can drill in a post on a flat top for your quick change tool post.
Just for fun
Tim Young
Oct 7, 2020
378
I take it you bought it used. Have you reached out to the guy you bought it from? Maybe he still has it.
AdBlock Detected
I've Disabled AdBlock
