- Jul 2, 2014
- 7,594
It is a shame that these lathes and tooling for them are kits needing lots of modification work, instead of something you can just turn on and use happily out of the box.
Thanks Mike. I need to adjust the gibs etc and also sort out my tooling. I feel the cheap tool holders and carbide inserts they came with could be much better because when I see youtube videos of others their tools just seem to cut without effort. Anyone have suggestions for good carbide tool bit holders? preferrably for CCMT (triangle) bits since I purchased a new batch of them.Where there's a will, there's a way! Glad you got it sorted, stioc. I bet that lathe will hog aluminum now!
Thanks for mentioning that. I'm aware of the issue and these are indeed the old cast iron plates, I haven't been able to find an inexpensive source for steel ones. They cost as much as a new press from HF. The good thing is that it's a 12T press, most of the issues were with the 20T press. I also usually put a plate on top of them if I'm going to be putting a lot of force on them. This was may be a 1-2T force so I didn't. I've been using this press for various projects for over 6-7 years and no issues but at some point I'll upgrade to one of the newer 20T ones.Congratulations!
Just checking on a safety note for the press picture. Is the press plate that the vice is on a steel plate, or cast iron? They are moving away from cast iron plates now because they shatter, and fly apart under load.
Thanks I'll check it out. I've seen a lot of the 'big guys' on YTube etc use a 6-jaw...I wonder if that's the best of both worlds (3 and 4 jaw)?Thats correct, your slide may be different to mine though.
It was just a generic cheap 4 jaw, I had to make a back plate for it.
See here.
aligning the holes in the back of a chuck.
My new 4 jaw chuck has 4 8mm fixing bolts on the back but the holes do not go all the way through so I cannot use a transfer punch. I need to transfer the hole centres on the chuck to the back plate so I can drill them. 1) How can I do this accurately? My first thought (only one actually) is...www.hobby-machinist.com
Bob, I completely agree! which is why I want a better lathe, leaning towards the 12x size like the G4003G. Although most just end up getting the PM 13x40GT and have great things to say about them. As I get older I lean towards spending the extra money and getting something that does a good job rather than it turning into another project. When I was younger I bought old beat up cars with 'potential' and enjoyed fixing them. Now I'd rather drive new cars that get me to where I want to go day and night without me 'tuning/fixing' them up. However, the flip side of that is since I don't make money off of my lathe/mill etc if I didn't have to tinker with them I won't have too many projects to do with them either lol What type of lathe do you have btw?It is a shame that these lathes and tooling for them are kits needing lots of modification work, instead of something you can just turn on and use happily out of the box.
