- Jan 25, 2015
- 2,558
You can make a tool to bend plexi with a 12v power source, some mdf, a spring, some aluminum channel and an old hair dryer.
You take the heating element out of the hair dryer and straighten it. Either get a very thick piece of mdf or take 3 pieces and glue them together, leaving a gap in the center. put your aluminum channel in the groove (hopefully you used the channel to size the gap). Put a screw at either end of the gap and take your heating element and attach it directly to one screw. Attach the other end of the wire to the spring and hook the spring on the opposite screw.
Now take the plexi and lay it on the mdf. Hook the 12v source up to either end of the heating element. Do not hook the power source to the spring or it will melt, hook it to the element where it connects to the spring. Make sure the element does not protrude above the MDF surface or it will scar the plexi.
In about 5-10 seconds, the plexi will soften over the groove, but remain hard over the mdf. You then hold down one side of the plexi and lift the other to the angle you want. Now either turn off the power and wait, or move the plexi off the element while holding it at the angle you want. In 0-5 secs the plexi will re-harden and you now have your shape.
Only woks for angle bends though. you need a different process if you want a circle shape.
Here's a similar one to what I made, he just makes it a little fancier by hinging one side of the mdf:
