Thanks
I had the day off today so here goes. My lathe has been on those rubber mounting pads. Specific size for the weight of the machine (1000 LBS). Always thought they could be a source of vibration, So I removed them, tapped the lathe bed flanges 5/8 x 11 Tpi . had some 5/8 carriage bolts milled the heads hex, and ground the bottoms flat. I replace all rubber floor mounts with these new adjusters. I have the bed right on level .I used my pals Starret 6" machinist level. I removed the head stock. The lathe had been totally apart about a year ago due to my moving. Anyway removed the head-stock, cleaned under, above, and in between. lubed the adjuster . mounted the headstock. Put my 3/4 ground rod (closest piece I have to concentric) via 3/4 collet, with about 11" overhang. Checked My spindle bearing adjustment (cold) per the manual .no run out . Ran my Starret last word indicator the length of the rod and adjusted the headstock as close as I could to 0. Removed the collet mounted my 3 jaw, centered my 2" mild steel . 6" length unsupported per manual. I was going to following the manual one cut. and one finish cut. Tool was sharp enough to shave with. Gibbs were all adjusted, It chattered so bad I thought stuff was going to fall off the shelves. I could not attempt to even start a cut. Just cant figure what I'm doing wrong. Removed the steel stock and went and purchased 3" by 7" length aluminum .Finally I can make a cut. I have the head stock adjusted to .001 over the length of the aluminum. I think by tomorrow I can get it where im satisfied . But it is still eating me why the steel will not cut as per the manual. I think I need someone with some experience to give me some schooling. Oh ya all the work tapping on my knees. and making the levelers all for not. Some one shoot me.
Any suggestions greatly appreciated
Frank
