- Nov 24, 2013
- 1,791
As most likely know I picked this up about a week or so ago. I never intended on doing any real clean up at all cosmetically. But the guy I got it from had taken a angle grinder to it and ate up alot of the thick under coat. Then painted the half facing him rust brown.
I had no idea it was just a rust casting under it all. But I took her down to the cast then used body filler and a ton of sanding. I started off hand scraping the head. It seemed like sanding it would be such a pain. Then I moved on to the rest. I used flap wheels and hand scraping to get er done. By rough cast, it is rough. The back almost has waves in it. Being I wont use bondo as a coating, that made life all the harder as it went on thick in some places. I hand sanded it so them thick sections were a bear to get back down to cast.
I am waiting on info for the rebuild kit on the head. When I rebuild it I'll tear down the head and paint it before putting it together. So for now it's just bare casting. I also dont see a need to remove the ram or turret as I dont see my self using them, and have no need to paint under them.
I hope to pick up the paint today as it's currently primered. I was thinking machine gray with black accents.
- - - Updated - - -
some more
- - - Updated - - -
some more 2
- - - Updated - - -
Last couple for now. A lot more work to go
- - - Updated - - -
some more
- - - Updated - - -
some more 2
- - - Updated - - -
