Cold Blueing
twhite
H-M Supporter - Gold Member
Sep 10, 2022
928
Looking for some solid info. I have some tooling lathe holders and the likes that I want to cold Blue. What brand works best that you have tried.
Thanks!
Cutting oil is my blood.
Caswell's black oxide finish or Brownell's Oxpho-Blue are both excellent (and about equal).
Most important is the process. Clean and degrease thoroughly. Then (contrary to the name of the process) - heat the piece(s). I like to boil them with something to keep them off the bottom of the pan. Let your parts boil for a few minutes so the heat can soak through. This heats and does a final degrease / clean.
Pull them out and rub on the bluing. I apply it generously and leave it on for longer than instructed...
When you're tired of waiting, wipe it off.
Card it (buff with #0000 steel wool or a good carding wheel).
Lather, rinse, repeat as many times as you like to get the darkness and/or gloss you're going for.
As a final step I toss my parts into used motor oil after the last step. This neutralizes the compound you've been using, soaks into the metal to protect it from rust, and seems to make the color a bit darker. I usually leave it for several hours.
To reiterate: the process is most important. I'd rather do it as desscribed above with Birchwood-Casey (probably the worst of the cold blues) than have someone use Caswell's blue and follow the instructions...
You might be tempted to try some test pieces, and there's nothing wrong with that, but if you're bluing a different alloy results may not be at all representative.
Good luck!
GsT
Thanks!
Here is a photo of a tool that I cold-blued.
I cold-blued the tool's mild steel parts using Birchwood-Casey's Super Blue. For prep, I used medium emery cloth to remove mill scale and followed that with fine emery and a thorough cleaning using denatured alcohol. Then I blued the parts -- repeating the process to deepen the blue -- and followed that with an over-night soaking in motor oil.
HTH, Bill
I bought some on Amazon Birchwood Casey Super Blue. Seems to work well. Oops, see Bill already mentioned it. Mike
Good luck!
GsT
Thanks for the in-depth process. I will head over to the Gun shop next week and pick up some.
I use Caswell, works great. Have you searched the forum archives? Plenty of information already posted.
Thanks!
I've had good success with Jax Iron Steel and Nickel Blackener:
Around here, it is much more reasonably priced than the products oriented to the firearms crowd.
Craig
