I am looking for a source for a coolant pump for my lathe. I would like to build a muzzle flush system for my South Bend Heavy 10. There is a ton of info about muzzle flush systems on the net. There is even one article with a part number for a MSC motor / pump combination. That one is around 600 bucks! Since I will be using a water soluble coolant, I do not need a high pressure pump. I am thinking that a pump that moved 2 - 3 gpm with about 40 psi would do the trick. I spend several hours searching the net for one - no luck. Does anyone have any recommendations? I have looked at the Little Giant system and that may be a possibility. Does anyone have one?
Thanks,
Earl
Thanks,
Earl
