I got the spindle out of the quill with the new 20 ton shop press I got at the local HF store. Now I need to go get a blind bearing puller to get the bearings out of the quill.The bearings are shielded with metal, not sealed with rubber. Ive seen videos were the shield was pried out like you are describing Matt. I will try it. The bearings in the quill are Federal 1205 RR... i found those to be fairly common. The bearings on the pulley stack are New Departure 1206. I found an equivalent Federal 1206 M. So if I mess up the shields, I feel good about getting new bearings, which I might do anyway.
