- Sep 2, 2013
- 5,100
If you found buildup in the copper pipe I'm guessing it came from the galvanized pipe in the system. I've done a lot of water line replacement, and while very common with galv pipe, have never seen that with copper, even with really nasty well water. I prefer copper for domestic water and if done correctly will last for a very long time. Have done literally thousand of solder joints with out failure. Follow Eddy's instructions above, would add to wipe each joint with a rag to smooth the joint and remove flux while still hot to prevent corrosion. I had a friend help me do some plumbing once and every joint he did leaked, as he insisted that you didn't have to clean new copper. As for pex use brass fittings and crimp rings with the proper tool for leak free results. Mike
The copper was put in after at some point and was nearly solid with mineral deposits.
