- Mar 25, 2013
- 4,625
I have a Jet 18" vertical bandsaw. I typically run a 14 TIP 1/2" bimetal blade either .025 or .035. thick. I just removed a Starrett .025 blade because it was missing some teeth. Otherwise that blade ran and tracked perfectly. I replaced it with a Starrett .035 thick blade. I set the tension correctly and adjusted the blade guides. This blade does not run right. It appears to have a twist in it and the teeth visibly move from left to right as it runs (this is not related to tooth set) I tried increasing the tension and re-adjusting the ball bearing guide without effect. This behavior results in a wavy cut that requires extra finishing. I think the blade is defective and has a twist in the material. I have run into this with one other blade which I ended up trashing. I hate to have to throw away a brand new $50 blade.
Have you seen this? Can it be straightened? Any other ideas?
I could try to return it but I probably bought it years ago. I always keep extras on hand.
