- Nov 25, 2015
- 8,344
you need to grind it and temper it.
it will crack there if not tempered.
Grind it and heat it with a torch until just blue, otherwise it will break.Just for fun I took an old blade that was missing some teeth and cut out the bad section, about 1". Then I tried to TIG weld it back together. I accidentally discovered that 80-20 channel is perfect hold a 1/2" blade. On my first pass I melted the teeth and had to start over. I set the welder at 60A and went gently on the pedal with sharp tungsten.
I know the weld is incomplete on the tooth side. I also welded the opposing side which looks better. I will run this and see if/when it breaks!
Weld straight through the teeth and leave the bead there a little full.My bet is its gonna crack there anyway cause its not resistance welded all the way through the teeth. Blade was otherwise scrap.
I put an indicator on the crooked blade and tried to straighten it further. Its better but not satisfactory.
Hammer your weld flat.I tried my TIG welded blade and it runs a little crooked at the weld cause I didn't have it aligned perfectly. I will keep it as a backup.
I put a new Irwin Diemaster .025 x 1/2 and it runs perfectly. No runout at all. It think a lot of these problems come down to whom is welding the blade. It probably varies a lot by supplier.
I was thinking that it probably doesn't matter how many welds are in a blade. If I invested in a blade welder I could make frankenblades from my supply of blades missing teeth. I can also run a blade that is up to 2" shorter based on the available adjustment.
