- Mar 3, 2017
- 745
I have a customer that requires a .020" slit about 1.5" long in a piece of 3/8 stainless. He said the slit could be, "...a little wider."
If it didn't have to be so thick, this would be an ideal place for electrochemical machining; in 5 mil shim, you'd just
laser-print a negative, apply bake-on resist, expose (with UV), develop, and etch (ferric chloride works, but
I've also used salt water and a bit of battery assist).
Practical methods for 0.375" plate include wire EDM, maybe laser cut. I'm thinking you'd want to send out either of those.
Here at home, I'd mill a step and clamp two plates together...
