I know drill bits will wander a bit, but I'd really like these to be pretty straight. The application is a plinth for my lathe. The holes are being used to hold it down with T-nuts in the lathe cross slide. Depth is about 2.3 inches, clearance hole for 3/8" bolts. I will be cutting on a Bridgeport mill, so rigidity is reasonably good. Material is 7075-T6 aluminum.
I have a decent set of drill bits, but I've seen them wander a little in deeper holes.
I have a boring head and bars, Criterion and Borite cobalt. 3/8" seems pretty small for a boring head though. And I would need to pre-drill enough to fit the bars. Depth is a bit of an issue as well. My smallest diameter bar has a min diameter of .25" and max length of under 2". I could perhaps come back from the other side, but having to indicate the hole again on the other side feels error prone. More due to the operator.
I do have some carbide end mills that seem like I could plunge cut with. 3/8" dia, just long enough to work. I've been leaning toward these and cleaning the chips out with compressed air periodically. The flutes are only about 1" long.
