• PHISHING SCAM attempt TARGETING HOBBY-MACHINIST members. It has been brought to our attention that a pop-up survey is soliciting userfeedback from H-M members. In exchange for survey information, the user is given an opportunity to win a prize if they pay for shipping charges. This is NOT a Hobby Machinist program, survey or contest. DO NOT click through the links. Close your browser immediately and restart your computer. Clear cookies, cache and log back into Hobby Machinist. Again, this is NOT a Hobby Machinist contest or survey - IT IS a PHISHING SCAM attempt to get your credit card information.To close this notification, click the "X" in the top right corner of this box.
D1-4 Chuck Mounting
Radials
H-M Supporter - Gold Member
Feb 7, 2018
101
Hello,
I just finished a disassembly and cleaning of the 3 Jaw chuck on the new to me Enco lathe I purchased recently. The spindle is a D1-4 and doesn't have any makings on the spindle to indicate the tightening range on the cams. Looking at a grizzly manual for a comparable lathe it seems that the cam should rotate between 90 and 180 degrees to be in the tightened range? I've got two cams stopping at ~110 degrees of rotation and the third at ~160 degrees when tightening clockwise. The face of the spindle and the back of the chuck look good and tight, and I've got very low run out on a 1" ground test rod so I believe everything is aligned properly. My question is does the tightening of the cams seem correct degree wise? This is my first experience removing/ installing a D1 style chuck.
Thanks,
Nick
darkzero
Global Moderator
Staff member
H-M Lifetime Diamond Member
Nov 27, 2012
6,383
Yep sounds like you're good. I like to refer the position by hour hands. 12:00 would be disengaged. Properly tightened should be between 3:00 & 6:00. Just make sure you don't get AM & PM mixed up though. J/K of course. ;)
It would be a good idea to index your spindle/spindle accessory. Clock the chuck or whatever in all 3 positions & check runout. Choose the lowest reading, then mark the spindle & one of the cams. That way you can always put the chuck back on in the same position & it should repeat well. Some spindles may already be marked with a dab of paint or something.
I just put a simple center punch mark on mine.
Radials
Feb 7, 2018
101
Yep sounds like you're. I like to refer the position by hour hands. 12:00 would be disengaged. Properly tightened should be between 3:00 & 6:00. Just make sure you don't get AM & PM mixed up though. J/K of course. ;)
It would be a good idea to index your spindle/spindle accessory. Clock the chuck or whatever in all 3 positions & check runout. Choose the lowest reading, them mark the spindle & one of the cams. That way you can always but the chuck back on in the same position & it should repeat well. Some spindles may already be marked with a dab of paint or something.
I just put a sime center punch mark on mine.
Ok, I'll give the clocking a try and see if it gets any better/ worse in the other two positions. I like the idea of marking the chuck too for a known repeatable good position as there are no markings at all on anything.
Thanks!
Nick
rock_breaker
H-M Platinum Supporter
Dec 31, 2010
756
I just got lost !! I have an Enco 14x40 sold as a D1-4 but only has 3 Lugs on it . The guys here saved me from disaster by telling me to put Layout dye on the spindle taper then mount and dismount my chuck. Using 400 grit emery cloth to remove the dye transferred to the chuck, repeating the process until the chuck stayed in place. This is my first encounter with the D1 mounting. I have used the lathe on random projects (probably less than 200 hours) and now find some run-out on a 1"x
12" test bar that I was going to check the tailstock alignment. Out of curiosity I stuck my pinky in 1 of the mounting holes to determine the correct rotation of the locking cam lobe. Turning the lobe counterclockwise seems like the correct way to secure the chuck onto the tapered spindle. Now I read that a fellow hobbyist turns his 4 lobes clockwise.
Like Radial's lathe there are no indexing marks on the spindle nor were the chuck lugs numbered so I haven't really got the indexing completed as described here. Got a lot of checking to do in the next few days.
Have a good day
Ray
mikey
Global Moderator
Staff member
Dec 20, 2012
7,253
I just got lost !! ... Out of curiosity I stuck my pinky in 1 of the mounting holes to determine the correct rotation of the locking cam lobe. Turning the lobe counterclockwise seems like the correct way to secure the chuck onto the tapered spindle. Now I read that a fellow hobbyist turns his 4 lobes clockwise.
Howdy, Ray.
The correct way to tighten each of the camlock retaining lugs is to turn them clockwise. There should be a line on each of these retaining lugs; positioning each one at 12 O'clock should allow the lugs of the chuck to slide into place on the spindle. Then each retaining lug is turned clockwise until it interlocks with the lugs on the chuck, securing the chuck in place so it doesn't fall off. Then you tighten each of the three retaining lugs clockwise until they are firmly snugged. The line on the retaining lug should be between 3 and 6 O'clock. If the line is not within this range, the depth of the lugs on the back of the chuck need to be adjusted in or out until the line on the retaining lug is oriented properly.
I am attaching something from Jacobs pertaining to the proper procedure.
NortonDommi
Nov 15, 2016
681
As long as the mark on the cam is between the two V marks all is good. I suggest going around a few times to snug up. I read somewhere years ago from a "master machinist" that you could just mount the chuck and crank the cams up. Try that with a dial gauge on a test bar and you will be surprised at how much run-out you end up with. You don't need to crank the hell out of the cams either. Righty-tighty, lefty-loosey. Make sure that the spindle taper, inside of taper in the chuck and the chuck backface and mating area on the spindle are super clean and then put a couple of drops of light oil on the faces.
Mark the outer of the spindle, the chuck backplate to match and at the same time the backplate and the chuck plus the jaw positions once you have found the best orientation as sooner or later you will need to strip your chuck down to clean it.
D1 mounting system is one of the greatest things since sliced bread I reckon.
Tozguy
Feb 15, 2013
2,403
The taper is a tight fit on my chucks so I make sure to pull the chuck onto the spindle as straight as possible. I first turn all the cams only to the 3 o'clock position. Then continue around turning gradually tighter while trying to close the space evenly until full contact.
I like the tight fit on the taper even if it makes the chuck a bit hesitant to be removed.
With practice you can feel when everything is home and locked up. If the chuck is on right there should be no adjustment possible by further tightening of the cams.
Bob Korves
Jul 2, 2014
7,326
It is important to check carefully (use a light from behind) if the back plate (or chuck rear face for integral mounting chucks) seats completely to the spindle face all the way around when mounted. It is highly common for the fit of the spindle taper to the chuck to be too tight, and the chuck is then only being held by a tiny ring of contact between the spindle taper and the recess. It also means than when tightened down, the first cam will pull the chuck to the spindle face on that point only, and the other two will have air gaps at the spindle face. The chuck being tilted will cause the chuck to wallow around, tipped from being in line to the spindle axis, and will never be repeatable or very usable. Check for the problem, and if you find it, see some previous postings on how to fix it properly. It is VERY easy to end up with the chuck loose on the taper and/or not concentric. This is an important inspection, and repair if needed, for any D series tooling.
Bob Korves
Jul 2, 2014
7,326
Amazingly, after I posted that, I finished troubleshooting and repairing a 8" Bison 4 jaw chuck, with an integral D1-4 mounting, for a friend. I went to test it on my lathe, which is also D1-4, and I cannot get more than one pin to engage with the cams at a time, and that is due to the spindle taper on my lathe will not letting it seat. It may have mounted to my lathe if I let off the pins one revolution each, but it still would have only been seating on the taper, not on the chuck face. I will have to take the chuck back to his shop and take a close look at his lathe before taking any action. I really hope someone did not trim the spindle taper on his lathe to fit the chuck... :eek 2: Well, I DID say in my post earlier this morning that THIS IS A COMMON PROBLEM! If you have a D1 series spindle on your lathe, you should take a very close look at how the chuck(s) fit the spindle and if they are registering on BOTH the spindle taper AND on the spindle face.
BTW, this is the first Bison chuck I have worked on, and it had some serious problems with fit from the factory. The tenons that guide the jaws were sloped high toward the chuck center equally on all three jaws, and required major effort to close the jaws. It is an older chuck, with zero other information on it other than the Bison badge inlaid in the face and 8/4 over 82 below the inlay. It must have been made on Friday evening or Monday morning, for sure.
darkzero
Global Moderator
Staff member
Nov 27, 2012
6,383
I've had 2 Bison chucks now, well 3, but only 2 with D1-4 back plates. From the factory they fit my spindle absolutley perfect. However they are not more than 10 yrs old. Not sure about the older Bison stuff but my backplates are blanchard ground. Some people like to to skim the face the mounting surface of the adapter where it meets the chuck mounting face to true it up but I didn't even need to do that.
If the face of the D1-4 mounting surface does not meet the spindle face, sounds like someone might have taken a skim cut there on the Bison. Can you tell if it looks like it has a turned finish rather than ground? I've seen people do this & that creates a big problem as you were pointing out.
I had a Chinese D1-4 back plate that had this issue. No visible gap but it pulled too tight onto the spindle. Needed a mallet to release it from the taper. I fixed it by massaging the taper on the adapter with emory cloth. I still need to tap it ever so slightly only by hand to get it release but at least it's usable. I don't worry about it cause it's for the stock 3-jaw that came with my lathe that I only use when polishing or sanding parts (beater chuck).
Hopefully they didn't try cutting the taper on the lathe's spindle like you mentioned, that's a big no no in my book. I would never touch the taper or mounting face on my spindle except for light stoning if ever needed. With normal & proper use, the spindle should never need to but touched.
Bob Korves
Jul 2, 2014
7,326
It has an integral D1-4 mount, no back plate. It is all Bison.
The chuck has not been altered, and has all the original surfaces. The owner and I took the chuck apart together, but we did not remove the mounting pins or change their adjustments. However, that is about what it seems like, about one turn of the pins short of fitting my lathe. I will ask him if he messed with them. At any rate, I will do the rest of the work at his shop where we will be dealing with his lathe.
darkzero
Global Moderator
Staff member
Nov 27, 2012
6,383
Direct mount D1 cam lock shouldn't be any different. Heck even my Gator D1-4 direct mount 4-jaw that's made in China (Bison copy, made when the VP of operantions left Bison & went to Gator) fits my spindle perfectly. Bison is usually good quality but again who knows about the older stuff (if that old) & the history of that chuck. As you said could have been made on a Monday or Friday, that exists for every company. :D
Hope you are able to get it fixed up for him & good luck.
rock_breaker
Dec 31, 2010
756
Thanks Mikey. I am stuck with some paper work but will get to the lathe next wed. or thur. Things like this seem to be overwhelming right now. I owe Bob Korves an explanation and an apology as I do have a tractor brake problem that is the near future as well. Back to the D-1 chucks; The Enco lathe is new but came at the the same time MSC got involved. As I have said earlier there are no markings on the spindle, cams or the chucks. Perhaps I am lucky that I got paint already on the lathe LOL. I may need the lathe to make a thinner fixed disk in the tractor disk brake stack.
Thanks again for the literature and I will be back after putting some time into the chuck. & spindle.
Have a good day
Ray
AdBlock Detected
I've Disabled AdBlock
