+1. Trash the drive that's in the treadmill. It was almost certainly set up to be as cheap as possible, although I know of a few exceptions.Hi.I use this kb drive.It works much better for machine use.
Do not go by the HP rating on a treadmill motor,go by the dc amps draw.
Jerico, where you at? I may be able to help you figure it out. I'm in E. TN.
Chuck
Get yourself a KB Electronics DC motor drive and don't look back. The KBLC-19PM is intended for driving permanent magnet (... PM...) motors, and is commonly available from eBay surplus sellers for $25 - $50. It's an industrial rated and supplied controller. There is a fair amount of experience in using these for treadmill motor conversions on lathes in the 9x20lathe group on yahoo.
And be really, really careful with all your wiring. This stuff can kill you. I *am* a professional at power electronics - although not at machining.
Bill,Hi.I use this kb drive.It works much better for machine use.
http://www.ebay.com/itm/KB-Electron...487?pt=LH_DefaultDomain_0&hash=item3f150fd00f
You can get a manual here--
http://www.kbelectronics.com/Variable_Speed_DC_Drives/DC_Drives_Chassis.htm
Bill L.
Jerico,
I'm taklking about the origional controller. I have "Freecycled" several treadmills. Got real lucky with 2, they had the famous MC-60 controller.
Most tread mill controllers have a 3 wire connection to a speed control pot. AC input, and DC out to the motor. I have an MC-60 controller and 2.5 hp motor running my X2 mill at the moment. Still in a "cobbled together to try it" state, but functional. So far, I like it and am considering spiffing it up a bit and making it permanent.
I'm near Kingsport, just off I81. I am on spring break next week, but have company until Thursday. Plus, I'm retiring in May, so will have time to assist if you need it.
Chuck
