Was it imported in from ?Upon further inspection I'll be returning the 5C collet/tool holder. After cleaning the grease off there is .002" clearance between the 5c collet holder and the cast housing. Although the grind looks okay I did not check dimensions. The cast housing ID is very poor. The widths of the spacer, graduated dial and the index plates are not uniform, as much as .005" from low to high spot.
