Dickinson toolholders
Suzuki4evr
Sep 29, 2017
1,129
Hi guys.
You know how you never have enough toolholders?...............................so I made 10
I guess it will still not be enough, but it will make a big difference. I started with a piece of mild steel 600mm×45mm×115mm and machined the sides to get it parallel.
I then milled out the middle to depth for the clamping section,
but.............something went wrong. I milled one half and when I started the other half, I noticed that on the first half the mill must have started to come loose an dug in slowly so it went deeper than intended. It would not have made a difference, but I just couldn't leave it like that and after chopping the material up in the right lengths, I welded it up and machined it again. Thats just the way it had to be done. I then had to cross my "T's" (get it?), by using the 8mm T slott cutter,but I completely forgot to take pics of this.
The next blunder was not mine and I was not happy about it at all. The long piece of material had to be cut up in the correct lengths of approximately 58mm. I marked it out and took it to a local engineering shop to chop it up for me on the radial bandsaw. This is what I got back.
Check the three on the right. Not square at all.
The operator did not check his work and work pride was not on his agenda. I showed the owners son and he was nice enough to not charge me.
After I fixed my blunder by welding it up and machining it down, I took some of rhe blocks to the lathe to drill appropriate holes for some of the boring bars and the rest I milled for the square toolholders.
The 12mm 4fluit mill performed nice at a 12mm depth of cut.
Then it was time to do the v-grooves. I did this by using my new digital protractor or inclinometer wich I bought via eBay, to set my mill at 45degr. to make the 90degr.v-grooves. What a handy little instrument to have.
On to the relief grooves in the v-groove wich was done with a 3mm endmill.
Most of the work was about done so I cleaned up all the remaining surfaces with a flycutter.
The last parts I had to make was the height adjusters. I made them out of EN8.
Well guys this was fun,it took me a long time,because I had to do it between jobs and there is a lot of machining involved plus the mishaps of course. I will dip my hand in nickel electroplating and nickel plate them to prevent it fro rusting.
Thanks for viewing.
Michael
Rooster
Apr 4, 2017
151
Greetings, they look great. The joys of making things you want and need.
plunger
Jun 1, 2018
134
That looks like a handy tool ,that protractor.I found getting the angles the most complicated part of this whole procedure. I did mine in two batches.I machined them sepritley in one batch and the second batch I made one looooong toolpost holder and then cut them in pieces.
But you haven't made enough.
Suzuki4evr
Sep 29, 2017
1,129
I also went with the looooong approach,but somehow I found that it can cause problems and for some reason it felt that it took longer. And yes,it will never be enough.
plunger
Jun 1, 2018
134
I actually did my last batch with your approach. But I did get them very close but blued them up and individually scraped them in. It was such a small marea that it went pretty quick. Doesnt the post office lose your e bay stuff.?What did you use for the tee. I had to make a t cutter for the slot.
Winegrower
H-M Supporter - Gold Member
Jul 29, 2014
877
Nice! I’ve thought about doing this, but the time required is formidable. I got a quote from a Banggood company on 20 CXA holders for $15 each...sounds pretty good, right? But I couldn’t wait maybe a month or so, paid between $20 and $26 to get started with a dozen. It’s not enough.
AdBlock Detected
I've Disabled AdBlock
