Dividing a circle by 359
The hard part of compound indexing
Is when you find index number is not found on the chart .
yes, thankfully forums like this exist to point people in the right direction. I had not even considered compound indexing, and in truth, I've never had to divide a circle before now using a dividing plate. I didn't know what to even search for. the book i found on the subject didn't mention it (or i missed it)
Compound infexing is found in books dating back to 1900
You find this old machinest Hand book as late as the 1950's
perfect, thanks. I am going to try to find a copy along with the treatise of gear wheels and a couple others. It seems the old timers methods are still applicable today for the hobby user, even if it's not as relevant to current industry.
After reading your explanation a couple of times, I am starting to grasp the concept of what you're doing. I'm not into astronomy, a couple of steel mills too close. Light polution........ It seems to me you don't need to go all the way around, simply a quadrant would suffice. That could be driven by a couple of stages of worm and pinion, adjusted to a clock. As in move "x" degrees in "y" minutes. Final speed adjustment would be as simple as a servo motor with a good power supply. The other possibility is that I am so far off the track that I just want to answer and can't really help.
The solution is pretty much just as you've described, a worm and pinion: a low speed motor connected to the worm, and the x, y connected to the pinions and a feedback loop that adjusts the rpm as needed. In terms of tracking an object, from the position you found it, you probably would never go past 180 degrees. I think some commercial work as you've described with a more limited range of motion since you can't track objects past the horizon.
vtcnc sent me a sample using a couple of tracks and it gave me some inspiration to apply the information learned here in a similar manor. the standard dividing plates on the rotary table are about 100mm/4" in diameter. I used that as a constraint and came up with this:
Each group A-F is spaced 90.25 degrees apart. So, starting at A-1, rotate left through 270.75 degrees, after you get to the last position for A-1, when you come back up to 0, you use the next track, A-2, this repeats until you hit A-15 @ 270.75 degrees, at this point you come back up to B-1 and repeat the sequence until you get to F-15, stopping one rotation short for 359 divisions. You can see with the blue lines that what would be A-16 lines up with B-1.
EDIT:
I have attached the original rhino3d + dwg and dfx in the dplate.zip file if in case anyone would like to take a look.
  • dplate.zip
Looks like you got a great plan.
This is such a neat project, I'll make you an offer.
Make and send me a blank plate. Give me a listing of all the holes in this format:
(X0.000 Y0.000 is center of plate)
X#.### Y#.###
X#.### Y#.###
X#.### Y#.###
I'll center drill then drill them on my CNC. I am not offering much, this is trivial on a CNC mill.
It found very old book by Brown and Sharp in early 1900's
I do have draws on the settings up on compound indexing
Dave
Sent from my SAMSUNG-SM-J320A using Tapatalk
Thank's for the offer, for the now, I would like to try to do the layout myself and vtcnc has offered to laser cut the disc. If anything changes, would you be okay if I messaged you then?
Good luck
Dave
