- Sep 29, 2017
- 2,253
My first instinct would be to braze it with a gas torch.
Anyhow, I have a dividing head wich I picked up a while back at the scrapyard and ...
Then I found that the end of the wormgear housing was broken of. That part is very thin walled. I don't how or why it broke.
Well I want to fix it and I came to the conclusion that I have to remake the part,because I don't think there is really a way to just add a new section on.
This sounds like the way to go and I got a better understanding of the brazing part. I have a few jobs to finnish up but then I will give it a go and document and post it here as I go. Thanks everyone would helped solve this problem. BEST FORUM EVER!!!!!!!!!!It looks like it's a centering scheme for the disk that fits inside the collar end.
So, you could turn the collar O.D. to make a shoulder, fit a tube onto that shoulder, braze/silver solder the
tube on, and machine the tube (which can be a lot tougher stuff than cast iron) to suitable dimensions.
As long as you turn it after the braze, it shouldn't be hard to make it accurate.
That way, there's no crying need to attach to the small area which is already cracked/damaged and of uncertain shape;
a turned surface to a small shoulder will define the braze joint and give lots of surface area for bonding.
