There are 2 different types of taper attachments that attach to the cross-slide: Plain and Telescopic. The plain one requires the cross-slide nut to be dis-engaged, thus disengaging the cross-slide feed as well. When you use the plain type infeed is adjusted on the compound only.OK, so you disengage the cross feed by a lever or something when using the taper attachment?
Telescopic type does not require the nut to be disengaged. It employs a separate spline incorporated on or within the leadscrew that allows it to float while still connected to the cross-slide nut. One end of the assembly is connected to the cross-slide infeed and the other is incorporated into the leadscrew. It is my understanding that the telescoping type allows the cross-slide infeed to be used during the process as the spline permits the leadscrew to function disconnected from the carriage. Hope this helps.
Best Regards,
Bob
