- Jun 7, 2019
- 367
Lol. Give it a go ! Can’t no more than chatterImagine your horror when you find out that i want to try it in a round column mill…
Don't think in terms of big cut/ small cut or high speed/low speed.I’m just learning this stuff but i’m the guy that is always cautious. I wasn’t planning on big cuts or speed. I just want to utilize the stuff i’ve been given in some form or fashion.
I’m showing off my newbie-ness…Don't think in terms of big cut/ small cut or high speed/low speed.
Think in terms of the right sfpm and low chip load per tooth. Once you sort that out your mill will let you know what too big a cut is.
I cheated and bought an app for my phone. FS Wizard Pro.
Once you calculate speeds and feeds you can give it a specific low chip load per tooth and the closest rpm you have that is under the recommended and it will tell you how fast to feed. On a regular endmill I'll go down to 0.002" per tooth or lower and down to 0.005" on your average insert mill.
It's honestly amazing how much it helped me with any type of end or facemill. Knowing these things will make staying within your window dramatically easier.
This is how I was taught to run other machines and how I run my machine tools. I’m built for comfort, not speed. And for what it’s worth for big end mills I use tool holders because there’s no way it can suck into the work with a set screw. Been there, had it happen so never more with a tool holder.Feel, and listening, also don't forget "experience is something you get right after you needed it"
I had to look up “chip load per tooth”. I didn’t know it was a consideration, but it makes sense to me. I’m sure that i’ll need an app too because i couldn’t understand the formula as presented. A lot of my education is going to be “feel” and i’m sure it’ll prove costly.
What would you use as a tool holder to try to do this? I’d like as many good opinions as possible! ThanksThis is how I was taught to run other machines and how I run my machine tools. I’m built for comfort, not speed. And for what it’s worth for big end mills I use tool holders because there’s no way it can suck into the work with a set screw. Been there, had it happen so never more with a tool holder.
