After fooling with a Chinese boring bar set for half an hour and getting crappy results
Bench grinder with the normal wheels?I have used a Dremel with a diamond wheel. Harbor Freight sells the diamond wheels at a fraction of the cost of the Dremel ones. https://www.harborfreight.com/diamond-rotary-cutting-discs-5-pk-69657.html
I see that Harbor Freight also has some larger diamond wheels with what looks like 1/4'' shank. https://www.harborfreight.com/large-diamond-rotary-grinding-wheel-set-4-pc-69658.html
But I normally just use my bench grinder.
