You need about 7° front clearance, and enough side clearance so the bottom of the carbide does not rub on the side. This is dependant on the diameter that you are cutting, but I always give it generous clearance. This is normally the biggest problem with the Chinese bars.
The angles are really not critical, there just needs to be clearance.
