- Mar 18, 2011
- 243
I am going to start a new project where I need some exact angles drilled into the circumference of a piece of aluminum 2" in diameter. I understand the part of using an end mill to make a flat, or even drilling the complete hole with one. But the part I am puzzling with in my head is how to set it up for the angles. I don't want to re-tram my mill so that is out. I have a 3-way compound angle vise (https://www.grizzly.com/products/Grizzly-4-Three-Way-Precision-Angle-Vise/T10059) so that may work. But I thought maybe somebody else ran into this before and has an easier way. Like is there a simple formula where I could just shim the aluminum to the correct angle and just use my regular vise? What it the most accurate way to get and measure the angle, say 30 degrees, with what measuring tool? Should a buy an inclinometer and if so, what would be a good one for short pieces, like 2" long?
Thanks,
schemer
Thanks,
schemer
