Yes.. works realy good..Hi, this is the first time I have heard about "annular cutters". Can you use them with a Bridgeport milling machine?
I would go with a 1/4 or 5/16 first, then chew through it with the 5/8. Assuming a 5/8 pin I would recommend 41/64 or 21/32 drill bit. You need a little clearance, the drill bit might actually drill on size. Makes it a bit hard to install the pin.
I second this method.I would go with a 1/4 or 5/16 first, then chew through it with the 5/8. Assuming a 5/8 pin I would recommend 41/64 or 21/32 drill bit. You need a little clearance, the drill bit might actually drill on size. Makes it a bit hard to install the pin.
Or Travers is having a one-day sale...Rent a Mag drill set up for annular cutters?
