- Nov 24, 2014
- 3,184
I failed to make myself clear it appears, sorry about that. I drill holes for tapping at or near the ANSI Unified Screw Thread internal minor diameter standards for the thread class required.
Using a hardware store tap hole chart does not provide this information and gives but one choice. 1/4-20 for instance, the drill size will be #7 (.201), the ANSI 2B and 3B standard, Minimum Minor Dia. is .196 the Maximum Minor Diameter is .207, I would therefor choose a #6 drill (.204) which is well within this range. the added .003 can make a big difference when machine tapping difficult materials.
Here are the ANSI 2B-3B standards. They may also be found in Machinery's Handbook.
https://www.engineersedge.com/thread_strength/internal_screw_threads_chart.htm
Thank you for the elucidation and the reference to the applicable standards. That's the kind of information that armatures need.
