- Nov 23, 2017
- 1,191
Pull out the bottom drawer and look under it at the bottom of the tool box for a manufacturer name.....
I did not know that - thanks! I have (4) dividers/calipers sitting on the bench to clean up, and was going to soak them in Evaporust.Evaporust will work fine for most rusty items. Just don't use it on spring steel like what tops off a pair of dividers or old style calipers. It can cause the spring to fall apart. Something about hydrogen embrittlement i don't quite understand. Scotch bright pad will clean up any back deposit left behind
That's wise counsel.Do the absolute minimum amount of cleanup to the tool box possible to take the loose old grease and grime off, and then let it be. All of those marks and all the wear are from your grandfather, in all their glory. Cherish them. Anybody can get a new and shiny tool box, but getting one well used by your grandfather is a really special treasure. Don't try to turn it into something it is not...
