Without the depth being controlled, that would also wipe out the threads on the next cut.....right?
I suppose there could be a depth stop on the outboard side of the headstock?!?!?
I agree.Honestly, I don't think this is any different then single point threading!
When he put the shaft back, it looked to me that he picked up the thread first before doing the next pass.hmmmmm......one thing I don't get.....
in the video before removing the long part for a trial fit, he bothers to mark the hex side between the two upper jaws, but I don't see that he marked the depth into the chuck jaws!
okay a second thing I don't get.......
I turned on english translation subtitles and got references to "fallopian" and "uterine".
are those references to female or internal threads?
one might have been referring to the half-nuts......not sure.....
-brino
Ile time is actually 9:00. 11:16 the the length of the video.If you freeze the video at the right instant (11:16) you can see he used a 3/8”-24 UNF tap, not an NPT thread. So, it really isn’t any different than single pointing except for maybe fewer passes to complete the thread and the taper that’s left near the end of the tap. That can be a pro or a con, depending on your application.
Tom
