[4]
El Hefe Lives
[3]
[10] Like what you see?
Chris Bettis
Active Member
Oct 23, 2015
214
Well I've been pretty quiet about things here on the forums lately. I had a few problems with my initial 12z mill, I will not get into any details. But I no longer own that machine.
Also as some of you know, Bill,(wrmiller) has recently upgraded to a knee mill and sold his 12z. After the problems with the first mill I was somewhat reluctant at first. But after much thought I decided that it was no longer a charter oak machine after all of the modifications and re working Bill has done on the machine. So I am proud to announce I am the new owner, unfortunately the Bill said I have to come up with a new name for it. (undecided). But I've been extremely happy with the machine so far. And am proud to call it mine. 9a372a809ab0dd07a872a632f3053dea.jpg
Sent from my LG-LS980 using Tapatalk
zmotorsports
H-M Supporter - Gold Member
Mar 12, 2014
1,494
Nice. Congrats. I'm sure Bill made it much better than original which will aid in the fun factor of using it.
Mike.
wrmiller
Chief Tinkerer
Mar 21, 2013
3,547
Long live 'The Boss'! ;)
You can proudly claim that you own a pretty much one-of-a-kind mill. (he's already experienced how powerful this thing is after smoking a couple of end mills...)
You can call it El Hefe, I don't mind. Just don't call it the "Miller Machine Works". ;)
Chris Bettis
Active Member
Oct 23, 2015
214
Mike.
Yes this thing is awesome, as Bill mentioned I already smoked an endmill cutting the chuck key 7/16 4 flute hss in 4140 it was going so smooth I decided to take a heavier cut, then things started glowing a dull orange.. oops. All the while the mill never knew it was cutting anything.
brav65
Sep 24, 2014
925
I encouraged Bill to add some glowing eyes to El Hefe! Congratulations on you new beast.
Chris Bettis
Active Member
Oct 23, 2015
214
Started a new quill stop today. Its made from a chunk of 3x.625 1018. The original quill stop only had 1 bolt holding it in place, a5a211c3a2620b4a3e08f44c171c0ff1.jpg3e2a231f8b9c1effd5f77e9c777a9d40.jpg67144a65d665457488e1bd51c7401aa2.jpg I forgot that I do not have a drill chuck yet so I cannot finish it until I get one.
wrmiller
Chief Tinkerer
Mar 21, 2013
3,547
Dude, you should have said something when you stopped by. I would have loaned you one. :)
Chris Bettis
Active Member
Oct 23, 2015
214
I didn't think about it until i needed to drill.
Chris Bettis
Active Member
Oct 23, 2015
214
Ordered all of my vfd control panel parts today. Should all be here by wednesday. Im thinking the bland white box is gonna need a good carbon fiber wrap
wrmiller
Chief Tinkerer
Mar 21, 2013
3,547
Are you installing a illuminated switch or other indicator that shows power is on? I just put in a order for a LED lit e-stop button, as I keep forgetting to turn off the power to the mill (I changed the VFD fans to temperature controlled in the settings so now I don't even hear those). I'll have to switch from negative to positive and run a return ground for the LED but I think that's it.
Chris Bettis
Active Member
Oct 23, 2015
214
Im installing a standalone led, hooked up to a keyed switch. From there it will go out to the e stop switch, and then on to the fwd rev switch. Im installing the key because the mill is at my dads. I dont want just anyone trying to use it while I'm not there.
wrmiller
Chief Tinkerer
Mar 21, 2013
3,547
Is the switch just right of the e-stop your fwd/off/rev switch?
Chris Bettis
Active Member
Oct 23, 2015
214
Yep thats fwd n rev. All of the legend plates on automation direct were backwards like the original switch. So i opted for a blank that I could fill in myself.
wrmiller
Chief Tinkerer
Mar 21, 2013
3,547
Yea, I hear you. I had to flip the legend plate on my switch after I re-wired it so I could just write a 'F' and 'R' on there with a marker. :)
Chris Bettis
Active Member
Oct 23, 2015
214
For those following along. Completely un related to the mill i did another thing today.62dd67e3f4be286ccd89ec1562d19f25.jpg bought an ammco 9,000lb 2 post lift.. Now i really need a bigger shop
FOMOGO
Sep 2, 2013
1,963
You won't regret getting the lift. One of the best purchases I ever made. Mike
Chris Bettis
Active Member
Oct 23, 2015
214
Thanks! The picture was taken at work they upgraded me to a 15k. So I bought the old lift from the company who does the installs for $500 Its now broken down on a trailer. Need to build a shop big enough to put it in.. Wasn't going to let that deal go to waste.
zmotorsports
Mar 12, 2014
1,494
Nice. I have an Ammco 10k pound two-post lift in my shop and I love it. I too need a bigger shop though.:(
Mike.
Chris Bettis
Active Member
Oct 23, 2015
214
Vfd controller mounted, wired, and programmed. The programming was a headache but after a couple hours of reading, head scratching, and cursing before the light bulb moment i got it all working. Only thing I'm curious about is my led lights are very dim. 24v + going to terminal 1 ground to terminal 2. Not sure if I reversed polarity that would make them brighter, or not work at all? The lights are led 22mm units from automation direct.
JimDawson
Global Moderator
Staff member
H-M Platinum Supporter ($50)
Feb 8, 2014
7,717
I think you wired them correctly. They are normally pretty bright. Two posibilities that I can see, maybe you ordered the 120V LEDs by mistake, or your 24V supply is not big enough to power the LEDs. What are you using for a 24V supply?
Chris Bettis
Active Member
Oct 23, 2015
214
Pretty sure i ordered 24v leds. But ill check the invoice. The power source is the 500ma 24volt positive logic supply from vfd which is a danfoss fc51
Edit: there are only 2 led's . pwr on indicator, and estop. I can turn one off and the other does not get brighter if that helps
[6]
[5] [7]
