[4]
Electric motor help.
[3]
[10] Like what you see?
kisuke47
Newbie
Feb 27, 2018
7
Likes
3
#1
Hi I'm new to these forums and hope to get some help I have an old baldor motor I would like to wire up its a single phase ac motor I'm trying to wire it for 115 volts it has a wiring diagram on the motor it says connect wires 1 3 8 and wires 2 J 5 which I have already done each of the wires are in there respective groups connected with wire nuts in the pictures I have them up and out of the way so you can see better so my question is where do I connect my nuetral and hot wires too from my power cord? and what do I do with the number 4 wire that's just hanging there? any help would be great thanks.
markba633csi
H-M Supporter - Gold Member
Apr 30, 2015
3,067
Likes
1,587
#2
Line wires go to 1 and 4 for 115 volt ac
Mark
benmychree
John York
Jun 7, 2013
2,756
Likes
1,996
#3
It looks to me that Line is connected to one and four and the other three are connected together and insulated for low volts. It does not seem to matter whether or not neutral and line are connected one way or the other.
dennys502
Active Member
Mar 15, 2015
114
Likes
116
#4
1 and 4 are your line connections.
brino
Jan 2, 2014
3,461
Likes
3,487
#5
@kisuke47,
It looks like you got a unanimous answer above.
I just wanted to say Welcome to the Hobby Machinist!
I hope you stick around and provide some pictures of the machine this is powering.
-brino
kisuke47
Newbie
Feb 27, 2018
7
Likes
3
#6
Thanks guys will connect them tomorrow and see what happens motor was given to me and it has been sitting for at least 20 years but turns freely since it is going to be wired for 115 does it matter how many amps the cord can handle? right now I'm wiring it to an old three prong cord will that be fine or should I go buy a higher amp cord just want to be safe thanks.
kisuke47
Newbie
Feb 27, 2018
7
Likes
3
#7
Hi Brino will do its going to be a homebuilt wood lathe.
dennys502
Active Member
Mar 15, 2015
114
Likes
116
#8
The wire size on your cord will be determined by the amperage of the motor.
kisuke47
Newbie
Feb 27, 2018
7
Likes
3
#9
It says 22/11 on the motors tag so I guess 22 amps for 115 and 11 amps for 230 volts? so to be on the safe side at least a 20 amp cord then.
markba633csi
Apr 30, 2015
3,067
Likes
1,587
#10
That sounds like about a 2 horsepower motor- it may trip the breakers in your shop (most 115 v outlets are only 15 amp) however you may
be able to start it unloaded on a 15 amp circuit just to test it
Mark
dennys502
Active Member
Mar 15, 2015
114
Likes
116
#11
12 ga would be a safe size for the cord. I'm guessing a 2 hp motor
Wow the time lag between posting is about 3 minutes.
tq60
Brass
Jan 11, 2014
690
Likes
405
#12
Should not run it at 120 as common outlet is only rated at 15 amps and there is a 20 amp outlet you ate pushing your luck so to speak.
240 would be better.
A smaller pulley would reduce the load as well.
kisuke47
Newbie
Feb 27, 2018
7
Likes
3
#13
Yeah it is a 1.5hp motor.
Eddyde
Bronze
Oct 13, 2014
1,421
Likes
1,208
#14
Use a 12 gauge power cord.
kisuke47
Newbie
Feb 27, 2018
7
Likes
3
#15
Thanks for the help guys connected all the wires and motor runs fine was a little stiff but once it ran for a bit spins smooth and easy but after sitting for over 20 years that can be expected I did have to replace the capacitors though now just need to put the cover back on take the fan off and give it a paint job.
Blackjackjacques
Active Member
May 20, 2017
147
Likes
52
#16
As everyone has posted, your connections for 120 V is across the 1 and 4 terminals as shown for the "Low Voltage" template - but it is not clear to me if the neutral should connect to the 1 or 4 terminal. You may want to check continuity between the motor frame and the 1 and 4 terminals to make sure that the "hot" potential does not manifest on the motor frame because of an unknown internal connection. However, you should be good if you measure infinite ohms between the 1 and 4 terminals and the motor frame (ground).
markba633csi
Apr 30, 2015
3,067
Likes
1,587
#17
AC motors (in fact all ac devices) don't care about polarity, you can interchange the hot and the neutral, makes no difference
Mark
i'm referring to input voltage polarity here, once you get inside the motor and start dealing with start windings and such then yes polarity matters
Blackjackjacques
Active Member
May 20, 2017
147
Likes
52
#18
Mark
I agree that there is no "polarity" issue with respect to AC machines themselves - but, there can be an issue with respect to electric shock safety if the frame of the motor is expected to be a ground potential and the hot is connected where there should have been a neutral. Older equipment sometimes presents concerns - but modern devices make certain that even the neutral is not grounded at the equipment.
markba633csi
Apr 30, 2015
3,067
Likes
1,587
#19
That's why a lot of stuff now is double insulated since our electrical outlet system evolved from what was originally a non-polarized system of outlets and plugs; it's still possible with adapters to plug in one of two ways
Always a good idea to have a separate safety ground wire
[6]
[5] [7]
